동글키를 장착한 후 PADS VX.1.2를 실행했는데 하기와 같은 License Error가 발생하였습니다. 확인 후 회신 부탁드립니다.
No license was found for feature padslogic. You have specified the following license location:
Using FLEXlm default locations for license files.
Please see the Mentor Graphics Licensing Quick Reference for help in setting license loactions.
The following FLEXlm errors were found: Server C:flexlmlicense.dat; Feature: padslogic License path: C:flexlmlicense.dat; For further information, refer to the FLEXnet Licensing documentation, available at "www.flexerasoftware.com".
Security system wasn't properly initialized: License request for padslogic feature failed The program will run in Demo mode.
ED&C |
컴퓨터-시스템 속성-고급 시스템 설정-환경변수에 가서
MGLS_LICENSE_FILE 변수가 제대로 설정이 되어 있는지 확인 부탁 드립니다.
