"오디날*ordinal) 3836(를) DLL LIBEAY32.dll에서 찾을 수 없습니다."
라는 메세지가 뜨면서 실행이 되지 않습니다.
EDNC님의 댓글
EDNC |
Error의 내용은 아래의 Technote를 확인해 주시기 바랍니다.
맨 아래 Solution을 보면 libeay32.dll파일이 Windows 7에서는 C:WindowsSysWOW64에 있을 텐데, 없으면 전체 검색으로 찾아서 이름을 바꾼 다음
프로그램을 다시 설치를 해달라는 내용입니다.
Technote대로 진행해 보시고 안되시면 다시 연락 주시기 바랍니다.
TechNote MG568805, 23 Feb 2012
DLL and OCX files fail to register with error code 182
Symptoms
When installing EE7.9.3 (and possibly other releases) various files fail to register with error code 182.
The module “C:MentorGraphics7.9.3EESDD_HOMEcommonwin32libpresym70.ocx” failed to load for Registration with error code “182”.
This message is then repeated for the following files:
symbolwizard.ocx
dxdatabook.ocx
iceAddIn.ocx
dxsymbolsvr.dll
dxdcczaddin.ocx
DxThunbnails.ocx
MGCLibDataGrid.ocx
MGCVariantMgr.dll
DXDRFToolkit.dll
LMCDocAddin70.ocx
If you then run DxDesigner or Library Manager, you then get the message "Can not find ordinal number 3836 in LIBEAY32.dll"
Causes
An old copy of libeay32.dll was located in C:Windowssystem32
TechNote ID
MG568805
TechNote Type
Solution
Updated
23 Feb 2012
Products
Expedition PCB
DxDesigner
Environment
EE7.9.3
Solution
Rename the file C:Windowssystem32libeay32.dll to be libeay32.dll.old
Remove the software, and re-install it
Note: The file libeay32.dll has been found in C:WindowsSysWOW64 on a Windows 7 machine, so if you get the message and cannot locate libeay32.dll, search your whole system for that file.
Related to this TechNote
•MG577867 The procedure entry point RWGetSecData could not be located in the dynamic link library RWUXThemeS90.dll
•MG577869 Expedition PCB (and PCB Browser/Viewer) crashes on launch without any error, and the process terminates immediately
EDNC님의 댓글
EDNC |안녕하세요.
Symptoms
symbolwizard.ocx
dxdatabook.ocx
iceAddIn.ocx
dxsymbolsvr.dll
dxdcczaddin.ocx
DxThunbnails.ocx
MGCLibDataGrid.ocx
MGCVariantMgr.dll
DXDRFToolkit.dll
LMCDocAddin70.ocx
Causes
TechNote ID
MG568805
TechNote Type
Solution
Updated
23 Feb 2012
Products
Expedition PCB
DxDesigner
Environment
EE7.9.3
Solution
