알티움 PCB 및 회로도 파일을 Pads로 변환하려 합니다.
사용환경은 VX2.10입니다.
Pads Layout Translator 를 사용하여 알티움 pcbdoc 파일을 변환하였더니 아래와 같이 에러가 발생합니다.
어떻게 조치를 취해야 하는지 가이드 부탁드립니다.
[I] Last saved as an Altium Designer version Release 20.0 file
[W] This file is Altium Designer Release 20.0 version - note the following: Vias support varying diameters across layerstack. If this feature is used in design, extra values will be discarded.
[W] This file is Altium Designer Release 20.0 version - note the following: File may contain pads with hole offsets. Hole offset information will be discarded.
[W] This file is Altium Designer Release 20.0 version - note the following: File contains new manufacturing rules. Hole To Hole clearance, Minimum solder mask sliver, Silkscreen Over Exposed Copper and Silkscreen To Silkscreen Clearance rules were introduced in Altium Designer Winter 09.These rules will be discarded.
[W] This file is Altium Designer Release 20.0 version - note the following: File contains new custom violations that replaced the old violation objects. These violations were introduced in Altium Designer Summer 09. The new custom violations will be discarded.
[W] This file is Altium Designer Release 20.0 version - note the following: Support was added for 32 Mechanical Layers. Objects on mechanical layers beyond 16 have been moved to Mechanical Layer 16.
[W] This file is Altium Designer Release 20.0 version - note the following: File contains assembly testpoint rules and/or settings. Assembly testpoint information will be discarded.
[W] This file is Altium Designer Release 20.0 version - note the following: New Custom Grids and Guides were introduced. Be aware that your design might contain Custom Grids and Guides that cannot be read in translator.
[W] This file is Altium Designer Release 20.0 version - note the following: New Structured Clusters were introduced. Be aware that your design might contain Structured Clusters that cannot be read in translator.
[W] This file is Altium Designer Release 20.0 version - note the following: New Clearance Rule subscopes targeting differential pairs were introduced. Be aware that your design might contain Clearance Rules using those subscopes that cannot be read in translator.
[W] This file is Altium Designer Release 20.0 version - note the following: Support of Solder Mask and Paste Mask expansions for Tracks, Arcs, Fills and Regions was introduced. Be aware that your design might contain Solder Mask and Paste Mask expansions for these types of primitives that cannot be read in the version of translator you are currently using.
[W] This file is Altium Designer Release 20.0 version - note the following: Air Gap Width previously controlled by Clearance rule is now controlled by Polygon Connect Style rule's newly introduced Air Gap Width (set to default value). Suggest reviewing each Polygon Connect Style rule's Air Gap Width attribute for correctness.
[W] This file is Altium Designer Release 20.0 version - note the following: Support of separate solder masks for top & bottom of pads added.
[W] This file is Altium Designer Release 20.0 version - note the following: Support Multi-line PCB Text added.
[W] This file is Altium Designer Release 20.0 version - note the following: Pad/Via hole size tolerance value added.
[W] This file is Altium Designer Release 20.0 version - note the following: Component parameters added.
[W] This file is Altium Designer Release 20.0 version - note the following: Support of backdrilling
[W] This file is Altium Designer Release 20.0 version - note the following: Support of waived violations
[W] This file is Altium Designer Release 20.0 version - note the following: Support of object specific keepouts
[W] This file is Altium Designer Release 20.0 version - note the following: Support of propagation delay for primitives
[W] Cannot find the Protel / Altium configuration file 'C:\Users\junyoung11.lee\AppData\Roaming\Altium\advpcb.ini'. Using Protel / Altium Classic Colors for layers.
[W] Cannot load the current color map from the PADS Layout configuration file. Using default colors.
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: HBC of kind RoomDefinition
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: HBB of kind RoomDefinition
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: HBA of kind RoomDefinition
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: Fanout_BGA of kind FanoutControl
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: Fanout_LCC of kind FanoutControl
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: Fanout_SOIC of kind FanoutControl
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: Fanout_Small of kind FanoutControl
[I] Protel / Altium rule type is not supported in PADS Layout. Rule type ignored: SilkToSolderMaskClearance of kind SilkToSolderMaskClearance
[F] 잘못된 인수가 발견되었습니다.
Total: 9 note(s), 21 warning(s), 0 error(s)
작성해주신 Warning 메시지의 경우 각 툴 마다 구조가 다르기 때문에 지원하지 않는 항목들에 대하여 출력해주는 메시지로 보여집니다.
따로 조치를 취할 수 있는 방법은 없어 보이고 변환 후에 원본 데이터와 대조를 하여 확인을 하신 후에 사용하시는걸 권장드립니다.
