Design to Library Part Consistency Check에서
Part Type 7-SEGMENT has the following gate pins that do not match to the Library part:
(1 9) (9 1).
Non matching Part Type 7-SEGMENT is used by the following parts:
U1 U2.
Part Type 74LS47 has a gate with 11 pins in the design and 14 pins in the Library.
Non matching Part Type 74LS47 is used by the following parts:
U3 U4.
Part Type 74LS90 has a gate with 11 pins in the design and 10 pins in the Library.
Non matching Part Type 74LS90 is used by the following parts:
U5 U6.
Part Type NE555 has the following gate pins that do not match to the Library part:
(1 5) (5 6) (3 7) (4 2) (8 4) (7 8) (2 3) (6 1).
Non matching Part Type NE555 is used by the following parts:
U7.
Part Type VRES has the following gate pins that do not match to the Library part:
(2 1) (1 2).
Non matching Part Type VRES is used by the following parts:
VRES.
[File]-[Library]-[Manage Lib.list]에 현재 사용하고 있는 라이브러리가 추가되어 있는지, 추가 되어 있으면 제일 상단에 위치해있는지 확인해보시기 바랍니다.
