라이센스가 만료된 것인지 데모로 계속 실행됩니다.
아래는 로그입니다.
9:37:12 (lmgrd) -----------------------------------------------
9:37:12 (lmgrd) Please Note:
9:37:12 (lmgrd)
9:37:12 (lmgrd) This log is intended for debug purposes only.
9:37:12 (lmgrd) In order to capture accurate license
9:37:12 (lmgrd) usage data into an organized repository,
9:37:12 (lmgrd) please enable report logging. Use Flexera's
9:37:12 (lmgrd) software license administration solution,
9:37:12 (lmgrd) FlexNet Manager, to readily gain visibility
9:37:12 (lmgrd) into license usage data and to create
9:37:12 (lmgrd) insightful reports on critical information like
9:37:12 (lmgrd) license availability and usage. FlexNet Manager
9:37:12 (lmgrd) can be fully automated to run these reports on
9:37:12 (lmgrd) schedule and can be used to track license
9:37:12 (lmgrd) servers and usage across a heterogeneous
9:37:12 (lmgrd) network of servers including Windows NT, Linux
9:37:12 (lmgrd) and UNIX.
9:37:12 (lmgrd)
9:37:12 (lmgrd)
9:37:12 (lmgrd)
9:37:12 (lmgrd) Server's System Date and Time: Wed Apr 20 2022 09:37:12 ??eCN??I???? C??A????A
9:37:12 (lmgrd) pid 4376
9:37:12 (lmgrd) SLOG: Summary LOG statistics is enabled.
9:37:12 (lmgrd) Done rereading
9:37:12 (lmgrd) FlexNet Licensing (v11.16.4.0 build 252457 x64_n6) started on 192.168.0.181 (IBM PC) (4/20/2022)
9:37:12 (lmgrd) Copyright (c) 1988-2019 Flexera. All Rights Reserved.
9:37:12 (lmgrd) World Wide Web: www.flexerasoftware.com
9:37:12 (lmgrd) License file(s): C:\MentorGraphics\Licensing\license.txt
9:37:12 (lmgrd) lmgrd tcp-port 1717
9:37:12 (lmgrd) (@lmgrd-SLOG@) ===============================================
9:37:12 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
9:37:12 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Apr 20 2022 09:37:12 ??eCN??I???? C??A????A
9:37:12 (lmgrd) (@lmgrd-SLOG@) PID: 4376
9:37:12 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.4.0 build 252457 x64_n6 ( build 252457 (ipv6))
9:37:12 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
9:37:12 (lmgrd) (@lmgrd-SLOG@) Listening port: 1717
9:37:12 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
9:37:12 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
9:37:12 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
9:37:12 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\MentorGraphics\Licensing\license.txt -l C:\MentorGraphics\Licensing\debug.log -z -s
9:37:12 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\MentorGraphics\Licensing\license.txt
9:37:12 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
9:37:12 (lmgrd) Starting vendor daemons ...
9:37:12 (lmgrd) Starting vendor daemon at port 1799
9:37:12 (lmgrd) Using vendor daemon port 1799 specified in license file
9:37:12 (lmgrd) License server manager (lmgrd) startup failed:
9:37:12 (lmgrd) File not found, path_to_mgcld
9:37:12 (lmgrd) Started mgcld (pid 8440)
9:37:12 (mgcld) FlexNet Licensing version v11.16.4.0 build 252457 x64_n6
9:37:12 (mgcld) SLOG: Summary LOG statistics is enabled.
9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT1
9:37:12 (mgcld) SLOG: VM Status: 0
9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT5
9:37:12 (mgcld) SLOG: TPM Status: 0
9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT6
9:37:12 (mgcld) Using options file: "port="
9:37:12 (mgcld) EXPIRED: dxvariantmgr
9:37:12 (mgcld) EXPIRED: edxpublsh
9:37:12 (mgcld) EXPIRED: edxverify
9:37:12 (mgcld) EXPIRED: edxwrtrdr
9:37:12 (mgcld) EXPIRED: lpepads
9:37:12 (mgcld) EXPIRED: m3dpdfoutput
9:37:12 (mgcld) EXPIRED: m3dplugin
9:37:12 (mgcld) EXPIRED: padslogic
9:37:12 (mgcld) EXPIRED: padsstd_c
9:37:12 (mgcld) EXPIRED: ploglibedit
9:37:12 (mgcld) EXPIRED: plogpadspcb
9:37:12 (mgcld) EXPIRED: plogpdf
9:37:12 (mgcld) EXPIRED: plogschedit
9:37:12 (mgcld) EXPIRED: plogshell
9:37:12 (mgcld) EXPIRED: variantmgrpads
9:37:12 (mgcld) EXPIRED: variantmgrsch
9:37:12 (mgcld) EXPIRED: visedatapads
9:37:12 (mgcld) License server system started on 192.168.0.181
9:37:12 (mgcld) No features to serve, exiting
9:37:12 (mgcld) EXITING DUE TO SIGNAL 27 Exit reason 4
9:37:17 (lmgrd) mgcld exited with status 27 (No features to serve)
9:37:17 (lmgrd) mgcld daemon found no features. Please correct
9:37:17 (lmgrd) license file and re-start daemons.
9:37:17 (lmgrd)
9:37:17 (lmgrd) This may be due to the fact that you are using
9:37:17 (lmgrd) a different license file from the one you expect.
9:37:17 (lmgrd) Check to make sure that:
9:37:17 (lmgrd) C:\MentorGraphics\Licensing\license.txt
9:37:17 (lmgrd) is the license file you want to use.
9:37:17 (lmgrd)
9:38:56 (lmgrd) Rereading license file... Requested from sever@DESKTOP-F06S3NU
9:38:56 (lmgrd) Starting vendor daemon at port 1799
9:38:56 (lmgrd) Using vendor daemon port 1799 specified in license file
9:38:56 (lmgrd) License server manager (lmgrd) startup failed:
9:38:56 (lmgrd) File not found, path_to_mgcld
9:38:56 (lmgrd) Reread: Started mgcld (pid 2448) 9:38:56 (lmgrd) Done rereading
9:38:56 (lmgrd) ...Finished rereading
9:38:56 (mgcld) FlexNet Licensing version v11.16.4.0 build 252457 x64_n6
9:38:56 (mgcld) SLOG: Summary LOG statistics is enabled.
9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT1
9:38:56 (mgcld) SLOG: VM Status: 0
9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT5
9:38:56 (mgcld) SLOG: TPM Status: 0
9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT6
9:38:56 (mgcld) Using options file: "port="
9:38:56 (mgcld) EXPIRED: dxvariantmgr
9:38:56 (mgcld) EXPIRED: edxpublsh
9:38:56 (mgcld) EXPIRED: edxverify
9:38:56 (mgcld) EXPIRED: edxwrtrdr
9:38:56 (mgcld) EXPIRED: lpepads
9:38:56 (mgcld) EXPIRED: m3dpdfoutput
9:38:56 (mgcld) EXPIRED: m3dplugin
9:38:56 (mgcld) EXPIRED: padslogic
9:38:56 (mgcld) EXPIRED: padsstd_c
9:38:56 (mgcld) EXPIRED: ploglibedit
9:38:56 (mgcld) EXPIRED: plogpadspcb
9:38:56 (mgcld) EXPIRED: plogpdf
9:38:56 (mgcld) EXPIRED: plogschedit
9:38:56 (mgcld) EXPIRED: plogshell
9:38:56 (mgcld) EXPIRED: variantmgrpads
9:38:56 (mgcld) EXPIRED: variantmgrsch
9:38:56 (mgcld) EXPIRED: visedatapads
9:38:56 (mgcld) License server system started on 192.168.0.181
9:38:56 (mgcld) No features to serve, exiting
9:38:56 (mgcld) EXITING DUE TO SIGNAL 27 Exit reason 4
9:39:01 (lmgrd) mgcld exited with status 27 (No features to serve)
9:39:01 (lmgrd) mgcld daemon found no features. Please correct
9:39:01 (lmgrd) license file and re-start daemons.
9:39:01 (lmgrd)
9:39:01 (lmgrd) This may be due to the fact that you are using
9:39:01 (lmgrd) a different license file from the one you expect.
9:39:01 (lmgrd) Check to make sure that:
9:39:01 (lmgrd) C:\MentorGraphics\Licensing\license.txt
9:39:01 (lmgrd) is the license file you want to use.
9:39:01 (lmgrd)
메일로 라이센스 및 교체 방법 송부드리겠습니다.
