라이센스 오류 문의
2022-04-20 10:00  |  Posted By 박광제
라이센스가 만료된 것인지 데모로 계속 실행됩니다.
아래는 로그입니다.
 9:37:12 (lmgrd) -----------------------------------------------
 9:37:12 (lmgrd)   Please Note:
 9:37:12 (lmgrd)
 9:37:12 (lmgrd)   This log is intended for debug purposes only.
 9:37:12 (lmgrd)   In order to capture accurate license
 9:37:12 (lmgrd)   usage data into an organized repository,
 9:37:12 (lmgrd)   please enable report logging. Use Flexera's
 9:37:12 (lmgrd)   software license administration  solution,
 9:37:12 (lmgrd)   FlexNet Manager, to  readily gain visibility
 9:37:12 (lmgrd)   into license usage data and to create
 9:37:12 (lmgrd)   insightful reports on critical information like
 9:37:12 (lmgrd)   license availability and usage. FlexNet Manager
 9:37:12 (lmgrd)   can be fully automated to run these reports on
 9:37:12 (lmgrd)   schedule and can be used to track license
 9:37:12 (lmgrd)   servers and usage across a heterogeneous
 9:37:12 (lmgrd)   network of servers including Windows NT, Linux
 9:37:12 (lmgrd)   and UNIX.
 9:37:12 (lmgrd)
 9:37:12 (lmgrd)
 9:37:12 (lmgrd)
 9:37:12 (lmgrd) Server's System Date and Time: Wed Apr 20 2022 09:37:12 ??eCN??I???? C??A????A
 9:37:12 (lmgrd) pid 4376
 9:37:12 (lmgrd) SLOG: Summary LOG statistics is enabled.
 9:37:12 (lmgrd) Done rereading
 9:37:12 (lmgrd) FlexNet Licensing (v11.16.4.0 build 252457 x64_n6) started on 192.168.0.181 (IBM PC) (4/20/2022)
 9:37:12 (lmgrd) Copyright (c) 1988-2019 Flexera. All Rights Reserved.
 9:37:12 (lmgrd) World Wide Web:  www.flexerasoftware.com
 9:37:12 (lmgrd) License file(s): C:\MentorGraphics\Licensing\license.txt
 9:37:12 (lmgrd) lmgrd tcp-port 1717
 9:37:12 (lmgrd) (@lmgrd-SLOG@) ===============================================
 9:37:12 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
 9:37:12 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Apr 20 2022 09:37:12 ??eCN??I???? C??A????A
 9:37:12 (lmgrd) (@lmgrd-SLOG@) PID: 4376
 9:37:12 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.4.0 build 252457 x64_n6 ( build 252457 (ipv6))
 9:37:12 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
 9:37:12 (lmgrd) (@lmgrd-SLOG@) Listening port: 1717
 9:37:12 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
 9:37:12 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
 9:37:12 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
 9:37:12 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\MentorGraphics\Licensing\license.txt -l C:\MentorGraphics\Licensing\debug.log -z -s
 9:37:12 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\MentorGraphics\Licensing\license.txt
 9:37:12 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
 9:37:12 (lmgrd) Starting vendor daemons ...
 9:37:12 (lmgrd) Starting vendor daemon at port 1799
 9:37:12 (lmgrd) Using vendor daemon port 1799 specified in license file
 9:37:12 (lmgrd) License server manager (lmgrd) startup failed:
 9:37:12 (lmgrd) File not found, path_to_mgcld
 9:37:12 (lmgrd) Started mgcld (pid 8440)
 9:37:12 (mgcld) FlexNet Licensing version v11.16.4.0 build 252457 x64_n6
 9:37:12 (mgcld) SLOG: Summary LOG statistics is enabled.
 9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT1
 9:37:12 (mgcld) SLOG: VM Status: 0
 9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT5
 9:37:12 (mgcld) SLOG: TPM Status: 0
 9:37:12 (mgcld) SLOG: FNPLS-INTERNAL-CKPT6
 9:37:12 (mgcld) Using options file: "port="
 9:37:12 (mgcld) EXPIRED: dxvariantmgr
 9:37:12 (mgcld) EXPIRED: edxpublsh
 9:37:12 (mgcld) EXPIRED: edxverify
 9:37:12 (mgcld) EXPIRED: edxwrtrdr
 9:37:12 (mgcld) EXPIRED: lpepads
 9:37:12 (mgcld) EXPIRED: m3dpdfoutput
 9:37:12 (mgcld) EXPIRED: m3dplugin
 9:37:12 (mgcld) EXPIRED: padslogic
 9:37:12 (mgcld) EXPIRED: padsstd_c
 9:37:12 (mgcld) EXPIRED: ploglibedit
 9:37:12 (mgcld) EXPIRED: plogpadspcb
 9:37:12 (mgcld) EXPIRED: plogpdf
 9:37:12 (mgcld) EXPIRED: plogschedit
 9:37:12 (mgcld) EXPIRED: plogshell
 9:37:12 (mgcld) EXPIRED: variantmgrpads
 9:37:12 (mgcld) EXPIRED: variantmgrsch
 9:37:12 (mgcld) EXPIRED: visedatapads
 9:37:12 (mgcld) License server system started on 192.168.0.181
 9:37:12 (mgcld) No features to serve, exiting
 9:37:12 (mgcld) EXITING DUE TO SIGNAL 27 Exit reason 4
 9:37:17 (lmgrd) mgcld exited with status 27 (No features to serve)
 9:37:17 (lmgrd) mgcld daemon found no features.  Please correct
 9:37:17 (lmgrd) license file and re-start daemons.
 9:37:17 (lmgrd)
 9:37:17 (lmgrd) This may be due to the fact that you are using
 9:37:17 (lmgrd) a different license file from the one you expect.
 9:37:17 (lmgrd) Check to make sure that:
 9:37:17 (lmgrd) C:\MentorGraphics\Licensing\license.txt
 9:37:17 (lmgrd) is the license file you want to use.
 9:37:17 (lmgrd)
 9:38:56 (lmgrd) Rereading license file... Requested from sever@DESKTOP-F06S3NU
 9:38:56 (lmgrd) Starting vendor daemon at port 1799
 9:38:56 (lmgrd) Using vendor daemon port 1799 specified in license file
 9:38:56 (lmgrd) License server manager (lmgrd) startup failed:
 9:38:56 (lmgrd) File not found, path_to_mgcld
 9:38:56 (lmgrd) Reread: Started mgcld (pid 2448) 9:38:56 (lmgrd) Done rereading
 9:38:56 (lmgrd) ...Finished rereading
 9:38:56 (mgcld) FlexNet Licensing version v11.16.4.0 build 252457 x64_n6
 9:38:56 (mgcld) SLOG: Summary LOG statistics is enabled.
 9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT1
 9:38:56 (mgcld) SLOG: VM Status: 0
 9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT5
 9:38:56 (mgcld) SLOG: TPM Status: 0
 9:38:56 (mgcld) SLOG: FNPLS-INTERNAL-CKPT6
 9:38:56 (mgcld) Using options file: "port="
 9:38:56 (mgcld) EXPIRED: dxvariantmgr
 9:38:56 (mgcld) EXPIRED: edxpublsh
 9:38:56 (mgcld) EXPIRED: edxverify
 9:38:56 (mgcld) EXPIRED: edxwrtrdr
 9:38:56 (mgcld) EXPIRED: lpepads
 9:38:56 (mgcld) EXPIRED: m3dpdfoutput
 9:38:56 (mgcld) EXPIRED: m3dplugin
 9:38:56 (mgcld) EXPIRED: padslogic
 9:38:56 (mgcld) EXPIRED: padsstd_c
 9:38:56 (mgcld) EXPIRED: ploglibedit
 9:38:56 (mgcld) EXPIRED: plogpadspcb
 9:38:56 (mgcld) EXPIRED: plogpdf
 9:38:56 (mgcld) EXPIRED: plogschedit
 9:38:56 (mgcld) EXPIRED: plogshell
 9:38:56 (mgcld) EXPIRED: variantmgrpads
 9:38:56 (mgcld) EXPIRED: variantmgrsch
 9:38:56 (mgcld) EXPIRED: visedatapads
 9:38:56 (mgcld) License server system started on 192.168.0.181
 9:38:56 (mgcld) No features to serve, exiting
 9:38:56 (mgcld) EXITING DUE TO SIGNAL 27 Exit reason 4
 9:39:01 (lmgrd) mgcld exited with status 27 (No features to serve)
 9:39:01 (lmgrd) mgcld daemon found no features.  Please correct
 9:39:01 (lmgrd) license file and re-start daemons.
 9:39:01 (lmgrd)
 9:39:01 (lmgrd) This may be due to the fact that you are using
 9:39:01 (lmgrd) a different license file from the one you expect.
 9:39:01 (lmgrd) Check to make sure that:
 9:39:01 (lmgrd) C:\MentorGraphics\Licensing\license.txt
 9:39:01 (lmgrd) is the license file you want to use.
 9:39:01 (lmgrd)
메일로 라이센스 및 교체 방법 송부드리겠습니다.
