ECO 에러 문의
2020-06-05 19:58  |  Posted By 김현수
ECO to PCB 를 했을때 에러입니다.
Line 6 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C501.
*          The attribute is also inherited from Decal C1005.
*          The change is not fully reconciled for cases where the schematic
*          does not support hierarchical attributes.
Line 8 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C503.
Line 10 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C504.
Line 12 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C505.
Line 14 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C506.
Line 16 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C508.
Line 18 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C509.
Line 20 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C510.
Line 22 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C511.
Line 24 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C512.
Line 26 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C515.
Line 28 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C550.
Line 30 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C551.
Line 32 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C552.
Line 34 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C553.
Line 36 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C63.
Line 38 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C77.
이렇게 나오는데 왜그러는건지요?
답변 부탁 드립니다.
DEL_ATTRIBUTE 메시지는 Footprint라는 속성을 지우겠다는 메시지입니다.
회로도에는 없지만 PCB 상에서 속성값을 지정하시는 경우,
[PADS Layout Link]-[Preferences]에서 Include Attributes를 체크해제하고 사용하시기바랍니다.
