usb를 다른 포트에 옮겨도 되지가 않네요.
인식이 안되는줄 알았습니다.
해당 에러 내용 확인 부탁드립니다.
The following FlexNet errors were found:
Server 1717@192.168.10.11: Cannot connect to license server system.
Server name: 192.168.10.11
License path: 1717@192.168.10.11;
FlexNet Licensing error:-15,10032
Server 1718@DESKTOP-B8J0MGO: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: DESKTOP-B8J0MGO
License path: 1718@DESKTOP-B8J0MGO;
FlexNet Licensing error:-97,121
listed below. Use LM_LICENSE_FILE to use a different license file,
Feature: pwrshell
License path: C:\flexlm\license.dat;
FlexNet Licensing error:-1,234
