pads 2007 설치문의
2012-06-15 17:10  |  Posted By dkyi
pads 2007 설치할때 라이센서가 계속 발견안된다하며
아래와같이 뜹니다. 어떻게해야되죠..?
    Server C:\Documents and Settings\All Users\Application Data\pads\2007\licensefile.dat: Feature has expired.
Feature:      plogshell
Expire date:  10-dec-2007
License path:  C:\Documents and Settings\All Users\Application Data -
FLEXnet Licensing error:-10,32
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Feature:      plogshell
Feature:      plogshell
    Server dummy.dat: Cannot find license file.
Feature:      plogshell
Filename:      C:\flexlm\license.dat
License path:  C:\flexlm\license.dat
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
    Server D:\Site_127319.txt: Cannot find license file.
Feature:      plogshell
    Server C:\site_127319.txt: Feature has expired.
Feature:      plogshell
License path:  C:\site_127319.txt
Feature:      plogshell
Feature:      plogshell
Feature:      plogshell
마경태님의 댓글
마경태  |
안녕하세요, ED&C 입니다.
현재 License File날짜가 만료 되었습니다.
회사로 연락을 주시면 업데이트된 License파일을 드리겠습니다.
