패즈 텐팅비아 문의의
2025-11-11 13:30 | Posted By 신승준
써멀 패드에 뚤려있는 비아를 텐팅비아 처리하려고 하는데 어떻게 해야되나요?
layout 버전은 VX.2.7입니다.
ED&C |안녕하세요.
이디앤씨 입니다.
Tent Via처리를 위해 아래처럼 진행하시면 됩니다.
해당내용 자료실에 등록해 놓겠습니다.
Selective Via Coverage and Exposure on the Solder Mask Layer
Via Solder Mask Expose
Vias Solder Mask Tent
PADS VX.2 and later
Certain situations may require that particular vias are covered over by solder mask while other are exposed such as with vias under a BGA. In order to accomplish this you can make a duplicate of your current via and make modifications to the pad stacks that will create solder mask exposure or coverage.
1. Go to Setup - PADS Stacks - Via.
2. Select your existing vias and modify its name to uniquely identify it such as STNDVIA_EXPOSED.
3. Select the Add button under the "Sh: Sz: Layer" column
4. Select the Solder Mask Top layer and click OK.
5. Set the Solder Mask Top pad size to the desired value to expose it in the Solder Mask.
6. Repeat for the Solder Mask bottom layer, if needed.
7. Click the Add Via button.
8. Click Yes to both confirmation prompts that appear.
9. Enter another via name, this time for the covered via, such as STNDVIA_TENTED.
10. Modify the Solder mask layer(s) under the "Sh: Sz: Layer" column to zero.
11. Click OK to the Pad Stacks dialog.
12. If vias are already placed in the design you wish to have covered by Solder Mask set your filter to only select by choosing the Filter from the right mouse pop up and checking the box for Vias.
13. Select the vias on the design to be covered, right mouse click choose Properties.
14. Change the via in the drop-down to your "Tented" via and click OK.
15. Define the Solder Mask Top Gerber document by going to File - CAM - Add.
16. Enter the name for the Solder Mask document.
17. Set the Document Type to Solder Mask and associate it to the Top layer.
18. Click the Layers button.
19. Select the Solder Mask Top layer and enable the Vias checkbox. This box must be enabled so that the Solder Mask layer information overrides the electrical layer pad stacks for the Solder Mask output.
20. Repeat for the Solder Mask Bottom, if needed.
ED&C |안녕하세요. 이디앤씨 입니다.
아래 해당 내용 참고 하시기 바랍니다.
기술지원 - 자주하는질문(FAQ) - (Vias Solder Mask Tent)Selective Via Coverage and Exposure on the Solder Mask Layer
