PADS Logic text 설정값 저장 방법
2018-07-30 09:53 | Posted By 조동철
PADS Logic text 설정값 저장 방법 문의드립니다.
설정 값이 계속 바뀌어 디폴트 값으로 설정하고 싶습니다.
ED&C |안녕하세요. ED&C입니다.
PADS Logic의 설정값을 Default로 하려면 변경후에 C:\MentorGraphics\(version)PADS\SDD_HOME\Settings\default.txt에 ASCII로 Export하시면됩니다.혹은 직접 default.txt를 편집하셔도 됩니다.(원본을 백업후)
관련 Technote는 아래와 같습니다.
PADS Logic: How to set a default Font for new schematics
Updated November 07, 2013
Summary
Set default height and width for text
Details
PADS2007 and newer
Following procedure explains how to set the fonts as a default by over writing the default.txt file.
1.Open a blank schematic file
2.Setup-Font, choose desired
3.Tools-Options, select the Text branch, set font parameters
4.File-Export and browse to the following location: C:\MentorGraphics\(version)PADS\SDD_HOME\Settings. Leave the export name as default.txt
5.Click Save
6.Within the ASCII output dialog, click Select All
7.Click OK
8.Close PADS Logic, open it back up again and begin a new design, the desired font should now be set as default.
Alternatively, you can make a copy of the existing default.txt file in the Settings folder and edit the file directly in Notepad. The section at the top of the file has entries for font height and width for items such as:
Pin Names - PINNAMESIZE
Reference Designators - REFNAMESIZE
Part Type Names - PARTNAMESIZE
Pin Numbers - PINNOSIZE
Net Names - NETNAMESIZE
The values that follow the entries in the default.txt file are font height and line width in mils units.
